Wet exhaust flapper replacement
seaya
C-248 C
FMLT2523G809
Reflections
I’m looking for a replacement flapper for the wet exhaust on my 2009 R25. It is 4 1/2” in diameter. Engine is a Cummins 2.0 QSD. Ranger parts department only goes back to 2014 on the thru hull exhaust tip and I cannot find any aftermarket flappers that are of the right diameter from reputable sources. Can anyone help me here?
I ordered a replacement flapper for my 2014 R4 with a Volvo D3 (which had fallen off while cruising back to Whittier….fortunately I discovered it missing at the takeout ramp). So it probably won’t work for you. If it’s larger you may be able to trim it. Otherwise make one from some similar sheet rubber.
I had to replace the exhaust flap on my 2012 R27 but couldn't find a proper replacement for the size. It ended up being a DIY project. I got the rubber on Amazon:
U-Turn Fasteners - Neoprene Rubber Sheet 3/16 Thick - 6 x 6 inch Black Rubber Flap (2 Sheets) Material for Gaskets, Leveling, Weather Sealing ($12)
I simply traced the old flap onto the new material and cut it out using a really sharp knife. If you dip the knife in soapy water, it makes cutting through the neoprene a LOT easier.
The small fastener plate was corroded beyond reuse but I was lucky enough to have a friend fabricate the part in his machine shop at work.
Old: https://photos.app.goo.gl/tgHXnZPqLvTdosA16
New: https://photos.app.goo.gl/iR7TG8dstLa5xAud9
Been working just fine so far this season. HTH, GF
I had to get a replacement for the flapper om my 2011 R27. As Mike said, Marine Hardware carries them. P/N is GETH-3.5 Flapkit. I corresponded with Ron Thomas at Marine Hardware, in Jul 2020 the cost was $45.50.
I took your advice and used the u fastener neoprene to make a new gasket. It worked great but guess what? I lost the small metal piece that holds down the gasket with the 2 screws, ugh. Any ideas? Can I get a new one? Small washers? Thanks
I need the 4 1/2" neoprene exhaust flapper for a '09 R25 Classic with the Cummins 2.0. Round with two screw holes. I followed the links in this thread but can't come up with the 4 1/2" OD. any suggestions?
Just go to a local Napa and buy a small sheet of 1/4" neoprene for about $20.
Draw, cut with heavy scissors and drill as needed. Make the holes a bit small to help hold the screws in place.
I made about 8 from the sheet I bought. Still using the 1st one.
Note: I didn't even bother with the little plate, it's been fine. You don't need it if the screws have good size heads.
Thank you. Others have referenced using 3/16" neoprene. Conscious decision to use 1/4" or what was available? Also, wouldn't a SS fender washer with one side curled up like the original plate also work on the screws?
