What is the purpose of this remote please?
OverTime
PNW South Sound
R-29 CB
OverTime
This remote control was on my boat when I bought it. I have no idea what this is for, no documentation on board. Marinco is a marine power company, they sell shore power cords. Any ideas? The SOS button is intriguing, I'm half Remote.jpg tempted to push it and see what happens! 😀
Thank you. I'll check it out. I'm not sure it's working correctly. I assume the SOS is a flashing beacon, either slow or fast. It looks like there is some sort of directional control also, I'll have to see how it works. I appreciate the info.
It’s great to have a remote. One person can use it while the other pilots the boat.
Or, I was thinking one could use it while tied up
And remember to turn your navigation lights first, otherwise the spotligth will not turn on.
Mine will work regardless of the nav. light switch position. The navigation light and the anchor light are on the same rocker but the searchlight iseems to be remote only, I can't find a switch for it. The remote started working correctly after a quick battery change.
Interesting. All I can find is the fuse for it
The remote for my searchlight on a 2025 R29 CB is on the dash to the right of the wheel. On the attached pic to the the right of the Garmin instrument cover.
I went ahead and mounted it on the dash next to the thruster remote on the left of it. It seemed like a natural fit.
Our RT 27 2011 has a jabso ? light, and it has a dedicated circuit breaker on the 12 volt panel.
It would help to have a picture of your complete panel at Avionics. It looks like a controller for your auto pilot/Garmin unit.
On our new boat orientation, Tim told us the two things that suffer most from lack of use are searchlight and windlass. Reminds me that I haven’t used either in a long while.
I have a 2023 Cutwater 30CB and the Marinco spotlight doesn't work, reading through these comments I'll try to switch on the Navigation lights as mentioned above, at the moment there seems to be no power to the Spotlight remote or the fixed controller on the helm. If this works it will be the easiest fix I have ever come across. thank you.
I wanted to follow up on my last remark to say that turning on the navigation lights to enable the spotlight to function did not work for me, i also tried changing the fuse, but I don’t seem to get any indication of anything when trying to turn it on. I emailed Marinco and am waiting for a response. But if anyone has any suggestions I’m open to try anything. Thank you.
I've always found the Marinco searchlight to be next to useless. Most of the other boats around me that run in the dark install much more powerful lights and/or FLIR or that other night vision company whose name I forgot. However, I don't find it an issue since I avoid ever running in the dark.
