Which "Multimeter" to get?
Someday*
C-30 CB
Yellowfin 24
Scotian
I am not electrically inclined but keep hearing about these items for use on the tug when trying to diagnose problems...to say their are a zillion different models of them is an understatement.
Is the a few that will do what someone like me will want but not be too overly complicated etc you can recommend?
Thx
I have a Fluke 325 clamp meter. I wasn’t cheap but it’s very nice. I had a $30 Southwire one before and it worked fine for checking voltage and trouble shooting simple electrical issues.
Whatever you end up with, make sure it has a feature to check continuity. Sometimes you dont care about current, volts, Amps etc. You just want to know a circuit is not broken.
Fluke model 101. $49 on Amazon. Does everything well but not for current. Plus, if you’re boating in the PNW visiting Vendovi Island will be even more special.
I did a ton of research and ended up with a Klein 380 (which I think has been replaced by the 390).
I believe I chose it because it was the best for DC applications in addition to AC, and it was cheaper than the marine-specific Blue Sea multimeter that had similar feature spec (while still being a professional quality tool).
I bought one very much like this on Amazon.
Cheap, but measures Ac-AC volts AC-DC amps, True RMS AC- quasi sine will read correct. and Temperature probe. Seems pretty accurate compared to more expensive.
https://www.amazon.com/VinTeam-Multimet ... C8XP&psc=1
Also keep a Harbor Freight one that was free in tool box- good for volts and home and really cheap.
