Windshield wiper
Whyknot
C-302 C
Grateful
One windshield wiper stopped working on my 2017 Ranger 25SC. What should I first look at?
In addition......do your wiper controls have a black rubber knob above the on/off rocker lever? If so this is a reset button that when punched in and reset the wiper unless its what Mike mentioned.
Jim F
Did you try pushing in the rubber button above the switch? This will reset it if it tripped.
Thanks for your replys. I tried the reset with no results so I will take a look at the connections.
Recently one of mine stopped, didn’t return to park. The other wipers worked but didn’t park. When the first one stopped it blew the park fuse located behind the helm on my 25 SC. To remove the motor you need to remove the wiper arm, battery terminal/wiper arm puller helps, there is also a small set screw on the arm holding it to the motor. Remove the inside screw and the motor comes out, there may be a spacer behind it. Note the wire connections before you completely remove it. If a wire came loose that’s the problem. If not remove the screws on the back and open it up. The motor should turn freely by hand, counter clockwise. If you need a new motor they are available online for around $200.00.
