AGLyme
“Sweetie” RT 31cb
- May 15, 2024
- Lyme, CT
- R-31 CB
- FMLT3129J213
- Just contracted to buy it, changing nm.
1) Packing gland water (the drip for the shaft), how does one "put pink in it", or, does it NOT have a "reservoir" of water therefore, when the boat comes out of the water for the winter... there is no water in the line anyway. ??
2) After the Engine, Generator and Air Con filter trap reservoirs are flushed with Pink, am I supposed to leave the Valves in the closed position for the winter? And leave the pink in the reservoirs for the winter... or, once the boat is pulled, do I open the reservoirs and allow whatever is in the through hull piping to drain out... ??
Thank you in advance for any advice.
