Winterizing C28 wash down Pump
Paul&Wendy
FMLC2827A919
My first year winterizing our C28. Where does the cockpit wash down pump draw sea water from? I can't seem to locate a seacock or strainer. Is it paired with another seacock/strainer?
On a 2017 R29 D4-300 Volvo, the wash down pump is adjacent to the starboard sea water inlet valve. Your's may be similar. A bilge heater is all I do for winterization in the Seattle area. Boat is in water year round.
On my C-28 the washdown draws from the same sea cock as the main engine. There is a marine hardware multi port strainer.
-martin610
On my 2019 C28 the wash down uses a shared strainer on the starboard side. The thru hull is the rearmost one on the starboard side
On our 2020 C28 it also draws from the same strainer on the starboard side that the A/C uses.
