AGLyme
“Sweetie” RT 31cb
- May 15, 2024
- Lyme, CT
- R-31 CB
- FMLT3129J213
- Just contracted to buy it, changing nm.
My 31cb is a 2013 boat. On the Port side, there are 4 hull throughs, (not 5 as shown in the current manual), I do not have a macerator.
When only the salon/helm unit is turned on, the hull through closest to the stern is spitting a strong stream + the hull through next to that is spitting a weak stream.
Ditto, when only the bow unit is turned on, the SAME 2 hull throughs are doing the same thing.
When both units are turned on, again… both hull throughs are spitting water as described above.
First, is this normal that both units would be tied into 2 water exit lines? I would have thought that each air con/ heater unit would have its own exit water line - not share 2 exit water lines.
And secondly, what is the trick to pouring the pink into the strainer ?
I keep breaking the vacuum and have to prime with seawater all over again.
Thx in advance.
Thx in advance.
