winterizing
pete s
C-302 SC
FMLT3111L718
Sveikas !
OK..... everyone knows how to winterize...
but
I have a question , specifically for the hot water system...
I find no drain valve on my hot water tank... there is an octopus of a fitting attached to the cold inlet side that consists of the cold water supply, a jumper to the mixing valve, and the pressure relief valve.... but no separate drain valve.. I was going to use the pressure relief outlet.. but it is almost completely unreachable, however I guess I could just hold it open and then just suck the mess out of the bilge with a shop vac.. (that bilge does not drain to the bilge pumps since the limber hole appears to have been sealed off at the factory by expanding urethane foam... why??)
I was pressed for time, so I just used a REAL LOT of antifreeze till the hot water tank and thence the hot water faucets drained pink...
Is this adequate??
Is there a better way?? (Next year I will drain the hot water tank somehow first... and then do the brilliant "hot water tank bypass method as is seen on the video
viewtopic.php?f=5&t=14263&p=95115&hilit=winterizing+fresh+water#p95115 one of the members posted.
Also.. tried to get antifreeze into the " city water connector".. but it appears blocked.. is there an "anti siphon" valve somewhere in this connection that I can't see that might be blocked ??
Pete S.
