Wiring pathways for spotlight, mast and starboard antenna to dash?
mannye
R-23 (Sterndrive)
FMLC3014G819
Stella Maris
I need to replace/reseal the spotlight on the top deck above the main cabin; add an AIS antenna to the mast and a Starlink cable out the starboard VHF antenna clamshell cable cover. Can you tell me how to access the wiring pathways from the dashboard to these three locations?:
1) spotlight mount above cabin
2) mast
3) starboard aft VHF clamshell cable cover
Thank you!
Manny Eusebio
2019 C-30 S HIN# FMLC3014G819
Hi there,
The routing of these wires is from essentially under the throttle box, aft along the side of the cabin, just under the side deck, and then upward at the C-pillar (the covered corner just above the fuse compartment in the quarter berth. It then routes to the center of the cabin top (covered by the head liner) and then out through the holes you see on the cabin top. Hope this helps.
Cheers!
Ralf
