BB marine
- Feb 1, 2016
- C-26
- Non-Fluid Motion Model
- Grady White 208
- PORT-A-GEE
baz":qww3f18f said:Brian: I really like this D4-300. It has plenty of grunt and it can provide a good sudden felt thrust forward when called for.... Oh and it's nicely and unbelievably quiet IMO with the excellent hatch sound insulation. Apart from the fwd end of the engine's belt location it has plenty of access for maintenance.... Oh, and I like the large oil retrieval pipe/tube on its starboard side for extracting the old oil rather than using the dip stick tube. It's just a very nice performing engine for my size boat.
Barry, I'm in full agreement. I think all the Volvo products are well designed engines. I really like the D3 which is a small displacement 2.4 L 150 HP, 200 and 220 hp engine that has a great deal of torque for its size and really packs some punch when putting the throttle down. The D4 even more with more displacement. My point was respect what they are. Realize the engines Displacement to Hp ratio and don't over prop it. If anything slightly under prop it. The Ranger Tugs and Cutwaters inboard diesels are not known to be fast planing hulls they are fast semi-displacement hulls. If the boats can run at 15kts to 20 Kts comfortably without over working the diesel power plant, running the diesel at no more than 70% load the engine selection for boat design gets a A+. Regardless of what rpm you run at 1300 rpm or 3000 rpm the engine should turn at or above Volvo's recommended max RPM D4 3500 ,D3 150hp 3000,D3 200,220hp 4000. I personally agree with many diesel mechanics that 2% to 3% above max rpm is optimal for engine longevity. The marine engine is in "overdrive" (comparison to a car or truck) all the time. It doesn't down shift to reduce load. The only way to down shift is to prop it correctly based on your Max RPM.
