At least with a used boat you expect items and equipment will need to be fixed and repaired/replaced. Hopefully the money that is saved will offset this loss!I did buy a new one last year. Still trying to get its problems fixed.
Really! What problems did you have on a new tug?I did buy a new one last year. Still trying to get its problems fixed.
Well, the chain locker was not draining for one...I made a entire post on it and the fix. It was quite surprising. The compass on the flybridge needed to be calibrated, I made a change for the better on our propane system and other small little odds and ends that needed to be touched up, re glued, realigned, tightened etc. I will relocate the fresh water pump soon to make access to the strainer possible, plus one of the hose clamps is actually obstructing the discharge from the pump, resulting in low flow. This is off the top of my head, I am on my boat a lot and am constantly tinkering, it's an aspect of the hobby that I really enjoy.Really! What problems did you have on a new tug?
UPDATE: The suction line was completely fouled with plastic shavings (I guessing it's from the drilling/tapping of the tank) There was even some past the strainer and into the pump. I cleaned out everything and rearranged the entire thing putting in a 4.5 gpm super quite pump. Everything is better than new now! P.S. The holding tank level gage isn't working on my "brand new boat" HeHe.I will relocate the fresh water pump soon to make access to the strainer possible, plus one of the hose clamps is actually obstructing the discharge from the pump, resulting in low flow.
