Y valve 2017 C28 location?
NautiTug
R-21 EC
No Reservations
I do not seem to be able to locate my Y valve on my C28 2017. Looks like the waste tank is in a different locations then the latest cutwater manual.
should be in front of waste tank above prop shaft area.
My tank appears to be under the cooler storage in the cockpit not near the shaft? I will post a pic once I am approved to do so.
Posted a pic in my album
ha! I didn't realize they moved the tank over there. my tank is under the stern seat.
do you have the macerator option installed? if not then you might not have a y valve?
either way I would follow the pipework to see where they go.
Found it. the pump in my picture is the macerator. and the handle for the valve was in my parts bag. I guess it's not a true y valve in the traditional sense now.
Still need to find a spot for next year to put a waste vent filter in. I dont really see where the line runs from the head to the tank. Just pump out line and macerator line.
I put a big orange filter on the vent line behind the stove. Four screws to pull it out and remove one of the propane line clamps to give you some room. There is enough room to position it so heat is not an issue.
Thanks. I have the convection oven and not full stove but I will pull it out over the winter and hopefully can mimic your set up.
If you wouldn't mind next time you change the filter could you take a picture of your set up for me please? Thanks!
