Brian B
- Apr 19, 2012
- C-26
- FMLR2512L910
- Non-Fluid Motion Model
- Sold in 2021
- GANSETT RANGER (2010) Yanmar 4BY2-150
After a 20nm run today I lifted the hatch to check the engine (4BY2150 768hrs) like I usually do. While looking things over I noticed a bar resting up against the alternator pulley. The pulley had ground a slight groove into the steel bar and some rubber dust was visible from the alternator belt. I could not figure out where this bar belonged. I'm traveling in FL with Mike Rizzo on Illusions, he has the 180HP, he found his under the port engine cover. This bar was spot welded under the cover, it's purpose seems to stiffen the port engine cover. You can feel this bar about 2" in from the port side.
Something else to check and be diligent about engine checks, had I not found this when I did it could have damaged the alternator.
