Toot541
- Jul 7, 2017
- C-288 C
- Tooter's Tug
My Garmin and Yanmar panel oil pressure indicators drop out (indicator needle) disappears at higher engine rpm about 1800. The indicator needle reappears at lower rpm. I told my mechanic to get a new oil pressure sending unit ($200).
I see on the Tugnuts it could be an ECU grounding problem or might be a plugged oil sender orifice or the ECU wiring harness is "bad". Has anyone solved this problem for sure?
Thanks for your suggestions!
Tooter's Tug
Tooter's Tug
