agreen88
- Mar 24, 2016
- C-24 C
- Non-Fluid Motion Model
- Cutwater 28
Today I was at anchor in my 2015 C28 (bought new from Hamlin's Marine in March 2016), running the NextGen generator (it only has 9 hours on it) and running the A/C unit in the cabin. It ran for about an hour in 90 degree weather, then the A/C shut off and there was no longer 120VAC available at the panel, but the generator was still running fine. I shut off the generator, checked the A/C breaker (it was not tripped) and opened it, then removed the cover of the generator and pressed the "reset" button, and restarted the generator. Still no 120VAC at the panel. Turned generator back off. Checked every breaker on the panel and none tripped. Opened and shut the main 120VAC breaker. Pressed reset on the generator again and restarted it. Generator starts right up and runs great, but still no voltage at the panel. When I go back to the marina, plugged in to shore power and A/C started right back up and 120VAC at the panel like normal. It seems like this would be a simple generator reset but that is not working.
Any ideas would be greatly appreciated. Thanks!
