Bsmith
- Oct 5, 2024
- Welaka, FL
- R-27 (Outboard)
- FMLT2735J223
- Non-Fluid Motion Model
- PDQ 34’ POWER CAT-SOLD
- Elixir
2023 Ranger Tug R27 outboard with Webasto air conditioner. We have a problem with the AC pump losing its prime after running hard up on plane. If we’re slow boating or at the dock there is no problem. The first sign that this has happened is when the high head pressure (check water flow) error code is displayed along with warning beeps. Instead of a steady stream from the AC outflow there is nothing. Re-establishing the prime by removing the outflow hose from the pump and priming the pump by re-opening the seacock makes everything work again. I do remember to shut off the thru hull for both the head and the AC before trailering or putting the boat on a lift but it seems that shouldn’t be necessary on a boat that stays in the water and is designed to run on plane. Has anyone had a similar situation? Could a scoop type water pickup installed for the AC water be used? Any suggestions? TIA.
