Submariner
Channel Surfing
- Feb 2, 2020
- Everett, WA
- Website
- www.letsgochannelsurfing.com
- R-27 (Outboard)
- FMLT2702C021
- Non-Fluid Motion Model
- https://tinyurl.com/yrv84xdm
- Channel Surfing
BB marine":31r7ag1t said:The ACR's have a Green light that will turn on when the ACR is closed. The ACR has a small ground terminal 12 ga wire yellow that must be attached to the correct terminal ( Ground). If it is attached to terminal (start isolation )or ( LED light) it will not turn on. This has happened many times to Ranger and Cutwater owners. It is an easy installation mistake to make.
I can speak to experience here as a Ranger owner: It's also fairly easy to stuff things into the port lazarette and accidentally knock off that yellow ground wire to the ACR. With the Garmin running, radar, sonar, vhf, etc... it was about 2 hours underway until I would get a "11.8 low voltage alarm", at which point I'd go back and parallel the engine and house batteries. Took me a bit to realize that an ACR wasn't working, thus my house battery was not being charged when underway.
I now have up on my Garmin dash System Voltage and Engine Voltage. They should both read either 13 or 14.something. If one were to read 12.6 and the other is 14.4, I'd start with the ACR ground wire.
