Attaching the Bimini 2023 R27
greyorca
C-302 C
I have the Bimini for the aft cockpit off for repair. Do you have any tips for reinstalling it easily (i.e. without trying to stretch it manually)? There appear to be small screws on some of frame parts. Are these to adjust tension in the frame? If so which ones do I adjust?
Thanks in advance.
The bimini top frame is not meant to be adjusted before the canvas is installed. Stretching the canvas over the frame helps it maintain its shape and fit properly. However, if adjustment is needed, the set screws can be loosened to reposition the frame. Keep in mind that moving the frame may affect how well the canvas fits.
Thanks Jared. In my case, I find it incredibly hard to stretch it enough to fully close the velcro tabs at the stern end. I've been putting the other end in the slot first and then working my way back. Is there an easier way?
I would slide it into the slot first, then go to the aft end and start there. Work your way down the sides, then do the middle. After that, go back to the aft side and pull a little more tension out of it if needed.
