Bottom paint
Jim: I apologize for high-jacking your post here... I hope you don't mind... just let me know and I can easily produce a separate post for my bottom paint and zinc additions etc.
Here are a few pictures showing zinc additions to our R25.
I found that the swim step bracing material below water line were badly eroded after some 2 1/2 years in the water so I decided to better protect the metal. Zincs were placed on all the swim step tubular bracings -- to better protect metal bracing components below water line. A good bonding between the tubular braces and the zincs was established as part of the install. I've had noticed quite a few boats in the yard had these type zincs on their swim step bracing supports. This was an easy install, an easy solution and little cost.
02naer
Small stainless wire connected/bonded between trim tab and the fixed hinge to help help avoid the fixed hinge erosion. All factory installed screw bolts were replaced with larger diameter screw bolts as the factory installed bolts appeared to be eroding far to quickly just below the heads IMO. Once the factory installed screw bolt badly erodes below the head (and this was evident) the head would easily twist off when being removed meaning the remaining bolt has to be drilled out... `a stitch in time saves nine' 😉
pk3ttg
Large zinc attached to transom. Bolted through the transom and wired to the exposed prop shaft via a brush connector, which in turn is bonded to the boat's bonding system. This should slow down the erosion of the prop shaft's zinc. One bolt (silicon bronze) is longer than the other and will carry/hold the interior wire connections. The installation was designed to make this zinc easily replaced.
1yysom
Barry:
It's all important and about how we can better take care of our boats, I welcome your thoughts and photo's.
Jim
Today I buffed & polished the R25's hull above the water line. It all went well until I came across an area on port side below navigator' port-side window. It appeared to be a large patch of about 12" with two 1" diameter plugged holes. It seems at factory this patch had been done to block up two holes. I've taken several pictures but it was very difficult to capture what I was seeing. No matter, here's a picture of what I was seeing which I've annotated.
ang6ks
...and here's a picture that shows the approx 1" diameter plugged holes that showed up when I was polishing. They are hard to see and the patch outline is just visible as a faint blue line that surrounds and wiggles around the two plugged holes. Hopefully you can see the faint blues line that outlines the extent of the patch.
1zuvcc
...and here's my polished hull... 😀 looks pretty darn good IMO.
955a09
Can anyone offer an explanation for this patch and plugged holes that presumably were done at the factory during manufacture. My guess is that they are holes for an A/C unit and plugged when realizing the boat was not going to be equipped with one!!!!!
Andrew: Do you have any insights about this ????? 😉
