JeffRad54
- Jul 23, 2019
- C-28
- FMLT2740K819
- Non-Fluid Motion Model
- None now
- MARGAUX
I've replaced the 16.5 Lewmar from the factory with a 35 lb. Mantus M2 for the Loop.
Unfortunately, the Mantus is a hair too long in the 'tooth' and bumps my bow plate.
Lewmar says I need a new bow roller. I think I should be able to drill through the outer bracket to the after roller bracket screw holes to make the unit one, vice pivoting as it is now.
Question is, how to find the center of the outside bracket to match the inside bracket screw holes to drill through the outside bracket to install a through bolt to hold the pivoting arm in place. There isn't enough room to drill inside to out.
Jeff Radwill
Jeff Radwill
