C-32 CB Stern Thruster
pshastings
C-32 CB
Beautiful Day
2020 C-32 CB stern thruster actuates and runs (and thrusts) for a couple of seconds, then blows the ANL fuse. This failure is repeatable.
I disconnected the solenoid and the fuse didn’t pop, so it’s either the motor or something electrical when it draws load.
Both fore and aft bilge pumps had failed so the motor housing was half-submerged for some time. (That problem has been fixed.) But when the motor actuates (before blowing the fuse), it runs seemingly normally (i.e., no apparent binding, definitely not locked up).
Last time a diver cleaned the bottom, he verified nothing in the thruster tunnel and thruster prop turned freely.
The mechanic is afraid that if he pulls the motor he’ll flood the boat. I find conflicting reports on the interwebs.
There is a fair bit of corrosion in the wiring and the cavity that holds the motor did have a good bit of water.
The bow thruster works fine and the battery is new, so I don't suspect that as a cause.
Questions:
(1) Is it safe to remove the motor while the boat is in the water?
(2) Is corrosion in the wiring a likely cause?
(3) Am I missing anything?
(As an aside, tugnuts won't support new tags. Suggest adding "stern thruster" and "lewmar" to tags list.)
