Wee Venture
- Aug 24, 2017
- C-302 SC
- FMLT3107G718
- Wee Venture
I was hoping someone would respond here who has experience with the Cutwater outboard model which I do not. The project should be doable. Not sure if you have the Yamaha isolator cable supplying your house bank and if so, if that type of charging circuit is current limited or not. Since a lithium battery can suck up a very large charging current, I believe you would need some means of protecting your alternator from overload. If current limiting is not built in you could install a DC to DC charger between the alternator output and your lithium house bank.Dmullen":pmktsgz8 said:I have a 2018 Cutwater 24 with the 300 Yamaha and a Abso 20 amp charger. My 2 house batteries are dying and need to be changed. When I purchased the boat, the people I bought it from included solar panels and two LiFePO4 batteries from Battle Born...not installed. I've had opinions all over the place....glad to see all your input.
The problem is that I'm not battery tech savey. I'm nervous about installing the batteries and all the other pieces of equipment that are impacted...ie my thruster and engine batteries. I would appreciate any info that any of you have.
Not sure what kind of solar panel controller you have but ideally it would have a charging profile for lithium. If your Abso charger has an AGM profile, that should work for your Battle Born Batteries. If you have an ACR (automatic charging relay) between your house bank and your engine battery, you may need to disconnect that. Otherwise, the charging current your alternator sends to the engine battery will automatically be shunted to the house bank in spite of your attempts to use a current limiter on the direct circuit to the house bank.
The Battle Born batteries are advertised as “drop-in” units because they have their own internal Battery Management System and because they do fine on a charger with an AGM profile. But the “drop-in” verbiage is misleading. Their website makes clear that modifications will need to be made to the system in order to accommodate them.
If you are nervous about installing the batteries but you have some experience with electrical circuits and wiring, you could educate yourself about the electrical system in your particular boat and research about the installation of battle born batteries specifically. Once you have a proposed wiring diagram, you could run it by the techs at Battle Born. I found them to be very helpful.
On the other hand, if this sounds fairly overwhelming you might want to turn the project over to a boatyard or marine electrician who can contract with you to get the job done. If you are based in Gig Harbor you are right around the corner from CSR Marine in Des Moines which does quite a bit of work for Fluid Motion and is a full service boatyard that includes electrical work. There are others in your area as well. You could also post on Tugnuts for recommendations of electrical contractors in your area who do good work.
Good luck!
John
