Creating the most effective window covers!
freedomvango
jacksonville, fl
Website
www.freedomvango.com
Let me preface this with how I define "effective":
Blackout capability, maximum thermal insulation and reflectivity, all in a lightweight, easy-to-install and remove package that also looks clean—depending on your fabric of choice.
Achieving all that typically isn’t cheap.
Only using reflective material fixes it about 60%
Canvas only is about 30%
Canvas and reflective is more like 65%
The key here is to have reflective and actual insulating materials in all the locations of the big fishbowl to achieve the best results.
The drive for this is to minimize the demand on the AC or Heater during extremes of the seasons in Florida. to maximize the effectiveness of the AC itself, control energy usage, thus maximizing solar production to prolong the amount of time I don't need to be at a slip
In the van world, we tackle this using products from VanMadeGear.com. A good example is this:
Now, the Ranger Tug presents some unique challenges. There’s nothing magnetic around the windows or trim, so installation isn’t as simple as using magnets alone. To solve that, I’ve decided to use two mounting methods:
1. Snads
Snads are snap bases backed with 3M VHB adhesive—no drilling required. You stick the base to the frame and install matching snaps in the shade. I’m using this method on all the side windows, skylights, and eventually the main aft doors and windows. It’s non-permanent, clean, and won’t become an eyesore over time. Velcro, by contrast, tends to lose adhesion—especially in Florida’s heat.
2. Magnets
For the roof hatches, I’m using magnets. By pulling the hatch trim down and embedding magnets behind it, the shade (which also contains magnets) will snap into place quickly and securely. I’ll probably use this method on the side ports too.
Pattern-Making Process
This part is easily the most tedious, but here’s my approach:
Step 1 – Build a frame template:
I use 2" RamBoard strips and hot glue to create a mock frame.
Template framing with RamBoard
Step 2 – Transfer to Reflectix:
Once I confirm the frame works, I transfer the shape to Reflectix to test fitment and adjust as needed.
Template check with Reflectix
Step 3 – Digitize the pattern:
I photograph the Reflectix template from above, import the image into design software, scale it correctly, and trace the outline.
Step 4 – CNC cutting:
The digitized pattern is cut on a CNC to ensure precision.
Cutting the pattern on CNC
Step 5 – Fabric prep:
Using the CNC-cut template and a hot knife, I cut the outer ripstop nylon, insulation, and interior canvas layers.
Material prep for sewing
Note: This isn’t the final material. The production version will use the same rigid insulation that VanMadeGear uses for better shape and insulation value. This version is mostly for rapid prototyping and verifying fit before I send the final digital files off to VanMade.
Here’s what the first version looks like layered with ripstop exterior, insulation, and canvas interior. Final versions will be solid color (gray or sand).
Prototype layer stack
Step 6 – Assembly:
I'm no professional tailor, but I can sew in a straight line. I clipped everything together and stitched it up.
Sewing assembly
Then I applied the bias tape, and just like that—done.
Finished prototype
Final Fit Test
Time to install and test fit on the boat.
First fit test
Final adjustment check
So far, fitment is great. The starboard window needs about an inch trimmed from the center, but otherwise everything is spot on.
Next Step: Send off the files and wait for the final product!
Plans are to do the 25s next, then move on to the 27s.
Stay tuned—more to come in a few weeks!
This is awesome! Loved the magnetic window covers I had on a Sprinter, seems like a similar design.
I finally was able to get the Hatches and skylight covers in!
The difference this makes sitting inside in the sun is absolutely insane. The heat from them is totally gone and instantly made a huge internal temp difference with the fans running.
Untitled by Grant Wilson, on Flickr
hatch covers are done by magnets
the skylight covers use Snads, an adhesive backed snap attachment like the other windows use.
On my 2011 RT 27 we have curtains on all the windows. Sides are or hanging on tracks that we pull back out of the way, and windshield is a long curtain with 5 snap fastners that hold it in place. Seems like what is being developed is to complicated and I see a storage issue when boat is being used. I have enough of a problem storing the Side Curtains for my Cockpit when I remove during the nice weather.
As do I!
The problem is still inadequate climate control
Where you are at, it may not be an issue. Where I'm at, it's unbearable at times.
Storage is easy. I put some overhead storage and they strap to that above your head out of the way on our boat
Our r-23 came with the canvas covers, but in the sun in Florida they don't do much. I get a 15 degree delta inside vs outside in direct sunlight at 11am as measured a number of days.
So when its 90-95 outside, it's 15 degrees cooler inside at that time. Without window covers it's the same or 5 degrees warmer than ambient
As do I!
We in PNW on the Columbia River at Portland, Oregon a temperate Climate.
Grant, I am finishing up the process of purchasing a Ranger Tug R23 and came across you making effective window covers for the R23. Incredible job and yes I imagine it’s a patients game going from conception to finish, well done. I leave where it will be extremely hot in the summertime and my R23 will be on a boat lift in the open.
I was wondering how far have you gotten with simi mass producing for the R23. If I can protect her while on the boat lift as well as on anchore enjoying family time I would consider being a customer.
Thanks Brian
We have a full set (hatch, skylights, side windows and windshield) from Freedomvango. Expensive, but perfect fit and very effective.
If you have an R23, you should consider all of what what Grant offers for the boat. He is beyond enthusiast for appropriate upgrades and his crew has a meticulous eye for details.
We drank his Kool-Aid and did the 920ahr lithium/victron conversion AND the custom fit floor coverings.
Thanks for the first hand experience with the shades, I definitely think it will be worth it as well to protect the boat and help lithium batteries its coming with when running the AC in the summertime. 920 amp hours, dang that’s awesome.
I like your MANTUS anchor mod on your tug. I am considering that as well.
Actually, yeah. They have a bit of a lead time since they are made to order, but i got you!
For the upper covers
Individual ones are here for the windows
Windshield and front windows for captn and mate are sold in pairs. The rear two for the galley and aft dinette are individual
