BB marine":3tuk9bpe said:
It may be old school but it still stands in school today. The same gauge used 30 or 40 years ago for propping is still used today Tachometer!...
And it is still valid today for setting up the boat. But it is archaic for operating it. As I thought you pointed out so well earlier in the thread with all the discussion about fuel burn
... The first question an engine manufacture technician should ask when there is a performance issue or a engine failure is what is or "was" your WOT RPM?...
And why do they ask this? First because it's their get out of jail free card because 90 percent of boats out there(inclusive of outboards) are just running the prop that came with it regardless of fit. Secondly it's because the instructions they give for operating their engines are for the general public with little/no knowledge of operating the equipment. Tell them to watch one thing which they can understand, the tach. Forget about all the other wiz bang instrumentation we now have like gph burn and/or engine load.
But in the context of our engines in these boats what does the tachometer guidance really tell us? For example, the notes on the data sheet for the QSD 2.0 state:
... Intended for use in variable load applications where full power is limited to one hour out of every eight hours of operation. Reduced power must be at or below 400 rpm of the maximum rated rpm...
This statement is only valid in the context of the actual prop curve matching the theoretical/design curve(IOW the prop perfectly matched to WOT rpm). Which it never will(exactly) due to changes in weight, sea conditions, etc. It's possible to follow this guidance and run with the throttle at the firewall all day long as long as I'm below 3600 rpm. And then when the turbo burns up get grilled by the shop technician about my WOT rpm
But if the note is taken in context with the theoretical prop/fuel burn curve what this guidance is really saying is that the engine should not be run continuously above about 70 percent load (6.1 gph@3600rpm/9.0 gph@4000rpm). Whether over propped, under propped, head wind, etc, rpm should be adjusted to keep the engine at/below 70 percent load.
...If anything the "climbing the hill" that sounds old school is more important in todays small displacement diesels. Engines that are producing more than 70 hp per liter. A 2L diesel producing 150 hp you don't want to lug.
Presumably by "lug" you mean to load the engine at low rpm. That may seem intuitive but regardless of engine size/weight we still get the benefit of a diesel torque curve. As long as it is operated below its continuous duty rating(in my case 70 percent load) the engine does not suffer and running at lower rpm has the benefit of producing less wear. Within reason. If low rpm loading is extreme then cooling can become an issue as the oil, coolant, and raw water pumps all move fluid proportional to engine speed. But in the context of a pleasure boat engine I doubt this is a practical concern.
...The way it was explained to me years ago (Mercruiser Training Center) ...
I wondered where that terminology came from. OK let's just agree that we're looking at life through a different key hole. The only time my boat has ever been up a hill was on the trailer and the prop made little difference
...you are over propped so you need to increase the slip to get your rpm's up to rated speed. Yes your boat speed may drop slightly but you will be operating the engine to design...
Reducing pitch should reduce slip. But I get you drift and it has nothing to do with whether I operate the engine to design. Per above I operate to the engine design load and rpm/boat speed fall where they may. Changing the wheel to improve performance has little to do with extracting power from the engine and everything to do with matching blade pitch to boat speed thereby efficiently turning that power into motion. Which unfortunately is a different answer for each hull design, typical loading condition, etc.
All that said I do need a flatter wheel. Since I operate 90 percent of the time at 25 percent load it never rises to the top of the to-do list. But it would be nice to be able to troll a little slower. As I'm currently set up the only way I can catch salmon is to troll in a circle to slow the baits down
