Levitation
- Aug 12, 2009
- C-248 C
- fmlt2510f809
- Charlotte Ann
Bill, you are still looking to spend "money" - which gives me the shiverin fits...
1. Your factory alternator is just fine... Lots of Tugs out there cruising with the factory set up... Until you have done at least one good cruise that proves otherwise, I would not change it...
If you are concerned about boiling the start battery follow Bob's advice and put a battery switch in the start battery to take it out of the circuit... (the negative lead is my preference for this) I would not do that until I see evidence that battery is taking more water than the others... (don't forget the thruster battery)
2. Buy a pair of golf cart batteries for the Starboard locker... They start at $75.. The more you pay the better the battery (usually)...
Get #2 wire and the 5/16" x 3/8" terminal lugs from Jamestown... Also the 3/4" dia. shrink tube with adhesive liner...
http://www.jamestowndistributors.com item #ANC 306503
(a 25' roll of red #2 is $75 - and paint the negative run with black paint at the terminal ends)
Put a battery switch (Blue Seas) in the positive line close to the battery set in the starboard locker... (lots of vendors on the web, including Jamestown)
The lug crimping tool is best bought from ebay such as item # 400193451060 or #250506888778 or similar...
This is not rocket science and I know YOU can do it...
3. The factory price of a solar panel is too much - they do have to make a profit and I do not begrudge them that - though I am unlikely to pay it...
Go to the Northern Arizona web site and talk to them... A single panel is ~ $300 - $500 and the charge controller is ~$70 and a bit of #14 wire... The cost of mounting is depends on how resourceful you are... I am adding a panel because I like redundancy...
4. The cut out relay for the ACR(s) when on shore power is necessary or there is absolutely zero point in having that expensive multibank charger... Fixing it is an $8 dollar relay from DIgiKey and a bit of #18 wire and less than 2 hours of your time... Just do it...
OTOH, Dr. Bob will just put a manual toggle switch in the negative line from the ACR(s) and flip it himself - he knows that parts left back on the distributor's shelf don't cost money and don't burn out when you are far from the marina... Listen to Bob, he has forgotten more about boats than I will ever know...
cheers,
cheers,
