Cutwater28GG
- Jan 14, 2016
- seattle
- C-28
- Non-Fluid Motion Model
- Cutwater 28
- Living The Dream
I was testing the engine bolts today as it was mentioned on a few other threads that others found theirs loose.
of the four brackets both bow end brackets had one of their bow end bolts loose. (also the hardest to get too :roll: )
- I am talking about the pair of 15mm bolts that bolt through the foot into the glassfiber.
From what I can tell there is a split ring washer between the nut and the black foot of the engine bracket.
one tightened up nicely. the other seems to spin and not tighten. its not loose per say but not as tight as I would like.
1. could this because the split ring washer is flattened out?
2. or the glassfiber has striped? (this doesnt seem right as I would have thought it would have a bolt on the underside?)
I didnt want to keep on turning the bolt in case I was making it worse. could perhaps the bolt on the other side just be spinning with the bolt?
need some advice on next steps!
