fishheadbarandgrill
- Jul 15, 2018
- R-29 Classic
- Non-Fluid Motion Model
- Sunfish; Vespa GTS 300 Super
- Sea Shanty
Thought I would pass along what I've discovered with my 6BY2-260 Yanmar engine fuel leak. Back in March I was doing my fuel filter changes. The engine mounted spin on filter was leaking at the mating surface with the manifold (called a filter head). What I discovered was corrosion on the mating surface of the manifold. The corrosion caused he paint to lift and give me an uneven mating surface. I was cruising in FL at the time I was able to use a combination of razor blades and emory paper to get as smooth of a surface as possible. No leaks after really torquing to filter tight. My plan was to replace the filter head at the next fuel filter change but after taking the boat out today, I smelled, then found a leak at the filter mating surface. A new manifold will cost about $500. Ugh. luckily, it appears to be an easy fix with a couple of banjo bolts on top and mounting bolts into the block.
