vladcut26":3t6f4cno said:Thanks to all!
Yesterday I used the "handmade fuel spill prev. device". It looks like the "NO-SPILL" plastic bottles which are pulled from market.
An used 1/2 gallon milk container with a 1-3/4" diameter hole on it's side (on upper area), silicon round on the hole edges, two masking tape strips to hold the container on a boat side. That is. It looks funny on a fuel dock, but it works! 😉
Vladimir.
10PoundHammer":3b021z12 said:Further to my earlier post . . . A couple of people have asked how the clean way device works with a chain (I I guess the pop bottle version too).
What you describe sounds like fuel is being trapped in the vent, typically due to a low spot in the hose. Fuel gets trapped in there and when air tries to leave the tank during filling it pushes the fuel that is trapped in the low spot out of the vent. It only occurs when fueling fast due to the air volume being enough to carry the fuel uphill to the vent opening. When fueling slowly the fuel will move out of the low spot and open a path for air to escape but there isn't enough air velocity to carry it all the way up to the opening. If you listen closely even when fueling slowly you will likely be able to hear/feel air surging rather than steadily exiting the vent when filling slowly. This is indicative of a low spot in the vent line.Shano":1guq8aq6 said:Scuba Too,
I am dealing with overflow from the vent tube opening when the tank is half or less full to 90% full only with high volume pumps...
