knotflying
- Jul 25, 2010
- C-28
- FMLT2731J011
- Non-Fluid Motion Model
- 25' Parker & 246 Robalo Cayman
- http://illusionsmikeandjess.blogspot.com
My galley faucet has lost significant pressure. I had this issue in the past and the easy fix was to clean out the small screen at the base connector at the handle. I have also cleaned the aerator. This time that does not seem to help. Pressure from the hose is fine when I run the water while disconnected and the head faucet is fine, so I would say the issue is with the faucet head. When using the main stream it is weak. Flip it to spray and it just flows out both center and spray areas without a spray. Any suggestions will be appreciated.
