Heading sensor issue
Amschene
C-288 C
We recently purchased a 2017 Cutwater C28. I’m still new to the boat and getting familiar with everything. Our heading on our Garmin is WAY off and needs recalibration. I spoke with garmin who took me through some steps to try and find the heading sensor but we did not have any luck after going through garmin settings etc.
garmin customer support has told me to contact Cutwater to see what heading sensor we may have, or if we don’t have it, I may need to purchase one. Also where is it located?
All of this seems odd since we have autopilot. Wouldn’t a heading sensor have been installed? Garmin said that our heading is likely going off the sensor that is built in to our main unit (Garmin GPS map 7612xsv). If that’s the case they said that particular model often has a heading that is way off. Any insight would be much appreciated!
HIN: FMLC2827K617
Hi there,
I'm sure your heading sensor itself is just fine. It's simply the system that needs to be re-calibrated. This is done by going into your autopilot menu and selecting the Seatrial Wizard. Here's a video that shows you how to do it. It will take you through the steps necessary. Once you get to the last step, setting north, the map will align with the correct heading of your boat again. Give that a go and tell us what you find.
Cheers!
Ralf
Woops. forgot to post the link
updating this thread with results. Heading originally appeared to be off by about 25-30 degrees. After following this video, the heading mostly fixed itself, and appears to be within 5 degrees of accuracy.
During the calibration I was on calm water, however it was in San Juan islands and there were random small waves. I was not able to get the calibration accuracy over 55 (out of 100). Now that I know how to re calibrate I hope to find another time to do so when in extremely calm water (perhaps super early morning).
Hi again!
I'm glad it helped. But since your results are still not as good as they can be, two things to consider: first, make sure that you're going fast enough for the calibration. The video says "your speed should be just above idle..." but that's a bit deceptive. It all depends on the boat and in many cases, that's just a bit too slow. Increase your speed a bit to see if your results improve. Second, in case you're comparing the radar image to a shoreline, be aware that it will not trace the exact line of the shore but the locations of objects on said shore that are able to reflect the signal back to the array. You're probably ahead of me on that but I'm just throwing that in, just in case.
Cheers
Ralf
