Morelords
- Jun 21, 2021
- R-29 CB
- FMLT2907G920
- Miss Calculated
Hi all,
For those of you that have installed a holding tank vent filter, would you say that it does help reduce the odor after flushing? If so, is it significant, or just a slight reduction?
For R29 owners, where did you install the vent filter? If the consensus is that a vent filter does help to reduce odors, I was considering installing one on the vent line just above the holding tank, as there is space for it, and it would be fairly easy to access. However, I am a little concerned about splashing blackwater getting into the filter, saturating the activated carbon media, potentially plugging it up, which of course would cause other issues (i.e. potentially collapsing the tank when pumping out). Are my concerns warranted, or am I just over-thinking it? Would there be a better place to install a filter?
FYI, I've read a lot about the holding tank odor issue on the Tugnuts and other cruising forums, and I now have Peggy Hall's book, but I'm not willing to increase the vent pipe size, nor willing to convert to fresh water flush (need to save the precious fresh water for other uses). I will also continue to try various tank treatments (Noflex Digestor, Raritan K.O., ...), perhaps more frequently than I have been using them.
Thanks in advance!
-Mike
Thanks in advance!
-Mike
