Tug@myHeart
- Jan 6, 2013
- C-248 C
- Non-Fluid Motion Model
- 20' Design Concepts Welded Alum 135hp Fishing Boat
- Tug At My Heart
As other stated always look for the obvious leaks and broken items......but it has been my experience that within the Salt water are creatures that die once trapped in your Sea strainer intake...Head and lines...raw water wash. Any place that outside water (salt or not) gets in, will smell sooner or later. When we bought our Ranger R25 is was awful, and I still bought it knowing it was possible to removed. I cleaned that boat till the stink went away. It was in everything. So it does not have to be actual sewage it could be Dead sea water stuck inside someplace. If you really wanted to clean the system out you should use city (chlorine) water with the recommended cleaning agents. All lines should be sanitized. Our boat stays in Fresh water, the tank can go a couple weeks with #2 use and the smell does not come inside the boat and is minimal outside.. I think much of the smell most experience comes from Sea water.
