knotflying,
Many others have reported using the Honda 2000I to power the A.C. with no problems.
However, I had what appears to be exactly the same issue as yours, with my Honda 2000i.
When the A.C. tries to start, the generator bogs down, and the overload light comes on.
When the overload light comes on, the Honda continues to run, but quits producing electricity.
I think I may not have been warming up the Honda sufficiently for it to go to full power when the load of the A.C. was applied.
I know the A.C. draws 1000 watts with the fan on high, as measued by the Killowatt device mentioned earlier by another person.
I also know the 3X rule of thumb mentioned by another person.
That is, you might need 3 times the running watts to start the A.C.
Give me a few minutes to do the math.
O.K. The A.C. may require as much as 3000 watts to start up.
This is clearly more than the Honda is designed to deliver.
So......it is a mystery to me how anyone is getting the good results they are reporting, using the Honda 2000I
But........I have found a way to start the A.C. using the Honda.
The first and most obvious thing, already mentioned by another person, be sure all the breakers on the A.C. panel are off. You don't want anything else ON when you are trying to start the A.C.
Be sure the Honda is NOT in ECO mode.
Start the Honda and let it warm up for a few minutes with no load.
Then turn ON the WATER HEATER breaker.
This forces the Honda to come up to full power, because the water heater requires 1800 watts.
Cycle the WATER HEATER on and off a couple of times.
I can only presume this "exercises" the mechanisim that causes the Honda to go to full power when a heavy load is applied. It also insures that the Honda is fully warmed up.
NOW...turn OFF the Water Heater breaker and turn ON the A.C. breaker.
Turn on the A.C.
The A.C. will start, BUT, and this is the scary part.
Watch the volt meter on the A.C. panel. When the compressor kicks in, you will see the meter drop to about 60 volts!
You will hear the Honda come up to full power.
It takes almost a full second for the Honda to come up to full power and the voltage to return to normal.
I am surprised am amazed that the drop in voltage to 60 volts does not blow out the A.C.
The honda is clearly not up to the task of starting the A.C.
Somehow it seems to work, but all the math says it should not work.
I got an ETQ 3500I generator to replace the Honda.
I have not taken it to the boat yet, so I cannot report on results.
I expect it should be able to easily start the A.C. even when other items are turned on.
In theory, it is almost the same as being plugged into shore power.
It is only a couple of inches longer, wider, and higher than the Honda, and weighs only 70 lbs.
It is about 300 dollars cheaper than the Honda 2000I.
Down side to the ETQ, there is not yet an after market fuel cap that will allow you to hook it up to an outboard fuel tank.
Unless you live in a big city, service is going to be a problem.
On the plus side, it is so cheap, long as it lasts at least a couple of years, if it conks out, I'll just throw it away and get a new one.
