That could be because you insulated the zinc from the bonding circuit.Gunner065":1iy7oz8i said:When I hauled out this year the prop zinc and associated bolt was missing. When I installed a new one, I rubbed some lanacote on the threads, installed the new zincs and put some 3m 5200 between the zinc and the bolts (filling the gap between the bolt head and zinc hole). 4 months after haulout and close to 250nm travelled, the zinc/bolt are still in the same shape as the day I installed them.
I agree with previous post. I would clean the surfaces well and get a big stainless steel fender washer and use that instead of the bolt being recessed. The issue is that the zinc starts to get smaller as it protects the running gear. Then it eventually works its way off,Gunner065":36ubfvx1 said:When I hauled out this year the prop zinc and associated bolt was missing. When I installed a new one, I rubbed some lanacote on the threads, installed the new zincs and put some 3m 5200 between the zinc and the bolts (filling the gap between the bolt head and zinc hole). 4 months after haulout and close to 250nm travelled, the zinc/bolt are still in the same shape as the day I installed them.
Gypsy":3p60c5st said:I added a collar zinc to the swim platform support. The support is bonded to the rest of the running gear. The zinc is doing its job and is deteriorating nicely.
Bill Gaertner
TomHall":2spamrte said:Gypsy":2spamrte said:I added a collar zinc to the swim platform support. The support is bonded to the rest of the running gear. The zinc is doing its job and is deteriorating nicely.
Bill Gaertner
Hi Bill,
What size zinc did you use? Is it a 1" ID or 1.25: ID? Not near my boat to measure.
-Tom
