mack6162":38lghqe2 said:
My wife and I tested a new R27 last fall and really liked it. We are looking for something that is stable in rough water and will allow us to (reasonably) comfortably stay on for up to two weeks at a time. We also like the idea of trailering the boat to different places across the country to explore new waterways. We would even consider staying on the boat when stopping on the road. We would like to learn the differences between the new OB boats and the Classic diesel boats. We have a sterndrive boat now and we really don't want another one due to repair costs for the outdrive and the cooling/exhaust system in general. I assume that an inboard has fewer issues than a sterndrive, but I do not know for sure. From reading here on the forums it appears that the Classic boat is a slower cruise. What are the other differences/similarities? What should we look for in a used boat? Any other thoughts would be much appreciated. We would like to become members of the Ranger Tug family.
We have an R27-OB and love it. We frequently do 2-4 day trips on her, but have done as long as a 10 day cruise, anchorage to marina to anchorage. 3 adults and 3 dogs. Our last boat had a gas inboard and a stern drive. I can totally relate to your comment about costs of the stern drive and the cooling/exhaust system in general. This was primarily why we wanted the outboard. It's raw water cooled, there's 8 anodes inside the crankcase, 2 anodes inside next to the thermostats... (anodes replaced every 300-500 hours). Yamaha built the F300 engine for salt water. It's got a 70 amp alternator that provides plenty of power even at idle, we use it as a generator to recharge our batteries on occasion.
I'd say probably the biggest differences between the inboard and outboard are the following:
- Where to store the dinghy. The outboard is in the way, the inboard allows for easy storage on the transom.
- Maintenance - The outboard requires a haul-out to replace the lower gear oil and water impeller every 100 hours.
- Speed - The outboard will get you to your destination in a lot less time.
- Noise - You won't hear engine noise in the cabin on an outboard unless you run the T9.9 kicker. (which is not to say it's quiet in the cabin. There's still the sound of the wind and waves, and at 25knots that can be louder).
- DIY Maint - The outboard is easier to physically work on, as the engine is not located in a tight space. This also opens up more storage space on the outboard since where the engine would go, is empty space.
There's a performance thread in Tugnuts where folks listed what they usually see speed wise. In general, the inboards are going to cruise around the 10-15 knots while the outboards can cruise slow, or can scoot along comfortably at 25 knots.
http://www.tugnuts.com/viewtopic.php?f=2&t=17591&p=115136&hilit=perform#p115136
We recently published a couple of video's on YouTube that you may find of interest.
Inboard vs outboard
https://youtu.be/LYoBPNLN3hM
We also did a walk-through of our R27-OB.
https://youtu.be/W5rSdDSGdsM
Trailering vs. moorage
https://youtu.be/OIsAnQ3_kFA
