Portable Battery Generator Use Such as Bluetti
pdo
C-288 C
Selah
Is anyone using a portable battery generator as 30 amp shore power when anchoring to supplement the house battery bank. I have a 2024 Cutwater 288 with the lithium house batteries and am looking for something to supplement while anchoring overnight. If you are using one of these, what manufacturer and model are you using, and what experience have you had with it? I see lots of people using these on RV's but cannot find much information on boat use. Thanks
I use a Bluetti Elite 200 V2 as shorepower. I get 20amps out of it if I recall. If were to do it today I’d get the Elite 300 with the 30A shorepower plug instead of using a 20A adapter. I’ve tried to run the electric grill off it and I believe it was a bit underpowered, but that was through shore power and next time I’ll try plugging the grill into it directly.
It’s a great addition - between the Bluetti and the 440W solar up top I’ve got zero power worries in my R27 NW with AGMs. My biggest question now is how to recharge the Bluetti, if it’s ever needed. Gut tells me to use the cigarette adapter and draw 100w - so very slow - and use solar to replenish.
  • Props
Reactions: pdo
I use a Bluetti AC 180 plugged into the shore power receptacle of my C 28. Works great. This provides 15 amps. Nice supplement. I have a generator but with the AC 180 I don't have run it as much.
Using it a lot right now as power has been out at my marina.
-martin610
  • Props
Reactions: pdo
We have a Bluetti ac200l. We use it in our camper plus on long trips on the boat.
Plug shore power cord in with an adaptor. Has large inverter. We primarily use it to charge the house bank back up but it could run any of our high load devices just not all at the same time.
The best way to recharge is with a 200 watt portable panel as long as you have sun. Otherwise it’s really just a backup battery. Otherwise recharge at a marina. It has a fast charger when plugged into shore power.
Thank you for the replies. Have any of you had any experience with these while using either Air Conditioning and/or the hot water heater?
We run the hot water heater off our ac200l. It can run the water heater for about 3 hours. I’m sure it would run the ac but I haven’t tried it yet. It has a 2400 watt inverter. Also guessing it would run ac for close to the same time as water heater.
  • Props
Reactions: pdo
An update
I think that I’ve got the shunt working properly and the 440W solar up top pumps out power like nobody’s business!
The Bluetti isn’t really needed to recharge the boat as I anticipated when I bought it but it sure is handy to run high wattage items and I suspect that it will be a backup to solar in the offseason.
The last question I had was how do I recharge the Bluetti? The cigarette lighter is slow at 100W and it seemed like a shame to have so much solar go to waste when the sun is pumping and my house is at 100%.
I considered a switch to swap solar direction from the house to a solar Solar input on the Bluetti, but this is soooo much easier:
Change max amp grid charging on the Bluetti to 3A and flip the inverter on. At the small cost of running the inverter, that will redirect almost all the solar to the Bluetti. I can increase it to 4A if I want to dip into the house a bit.
Simple solution for when the sun is pumping!
