Possible mod for R27/OB's furnace access & maintenance
baz
Subject: Possible mod for R27/OB's furnace access & maintenance
The Webasto diesel fueled forced air heater unit is located behind the Microwave for the R27/OB. For the 2018 early builds the furnace's pump/filter is located adjacent to the furnace, whereas for later builds such as for the late 2018 and 2019 the furnace's pump/filter is located under the galley sink area offering a much easier access than on the early build R27/OB boats.
What can be done to make the pump/filter more accessible for the R27/OB's that have the pump/filter adjacent to the furnace unit ?
I've noted that on the R29S there's a cabinet door beneath the helm seat on the starboard side of the vertical fiber glass. I'm assuming this allows access to the R29S's furnace and presumably the pump/filter.
I shall remove the Microwave on my R27/OB to see where the furnace and pump/filter box is and to see behind the forward facing fiberglass to see how much can be removed for an access door/panel. If the clearances look good I will endeavor to cut a rectangle and place a door/panel over the exposed opening. This should then give great access to my R27/OB's furnace and pump/filter box.
Barry,
My Garmin AIS 600 unit is mounted on the inside face of that cavity below the helm seat behind the MW. Wires and cables are running to/from unit to starboard hull where the Webasto furnace is located. My pump is located below the galley sink. Removing the MW is easy and you will see exactly what you have to deal with.
If I were you, I would buy a 2019 R29S and let the next owner of your R27-OB worry about it!
Bob & Kim
The Doghouse 2
Yea.... my thoughts exactly.... 😉
