wtsawyer
- Nov 28, 2013
- Savannah, GA
- C-24 C
- FMLS2427K718
- GUARDIAN
I'll be volunteering with the USCG Auxiliary this summer on Penobscot Bay, Maine when I head north from here in GA.
I'm very worried about lobster pot warps becomming wraped around my wheel. So far, the local Hinckley yard has proposed installing a well-known, rubber U-Joint to extend the shaft/wheel far enough beyond the keel's end for room for a set of "cutters". The added benefit would be quieter drive line noise as used on Flemings and other yachts.
I prefer the idea of extending the existing keel strap (about 5' long along the keel now) beyond the wheel so warps might simply "slide" off the end and miss the wheel.
Obviously, the wheel could be damaged by a bent strap in any heavy grounding, but I think the wheel's at risk in such a hard grounding without extending the strap in any event.
A second consideration would be to "close" the space between the keel, running under the wheel, and attaching the strap to the bottom of the bronze rudder at its pivot point. However, the same issue is raised about damaging the rudder in a hard grounding and I'm uncertain how to deal with dissimilar metals.
Question: Have you dealt with other's concerns about wraping pot warps around an unprotected wheel/shaft?
Care to share any thoughts on the "cutters" vs. extending the keel strap?
Thanks!
Cdr Tom Sawyer, USCG Auxiliary
Thanks!
