Pro Mariner TruePower Combi Replacement
JeffreyAC77
2015 R31-CB (LE)
Lake Union, Washington
R-31 CB
FMLT3106E415
State of Mind
My 2015 R31-CB (luxury edition) inverter/charger no longer works properly and I believe is out of warranty. Would someone from the factory suggest a proper replacement for this unit?? Also, can you quote me a price for this replacement?
thank you.
Hello,
I'd stay with Pro Mariner as apposed to switching brands. That'll make the install straight forward when you put the new unit in.
At the factory we don't stock the Pro Mariner Combi units but if you're in Redmond, Fisheries Supply would be a good resource to purchase a new unit. They're located on North Lake in Seattle. Here is a link to their website, www.fisheriessupply.com
-Kenny
Thanks Kenny. The unit installed (Pro Mariner) no longer exists.....is there one you would recommend as a replacement?
If that's the case I'd install the Kisae unit we're currently using. You can order one through our parts department, parts@rangertugs.com.
Thanks Kenny. Would you please specify what unit that is for my boat?
We had the Pro Mariner Combi 1500 in our R25sc. It was giving us trouble so I switched it to a Xantrex Freedom X 2000 and we are very happy with it. It fit in the original location and the wiring was similar enough to be a straight forward install. I was even able to use the original data cable to mount the remote panel at the helm, so no wire fishing. It is a pure sine wave inverter, so our microwave works on it without complaint; we just keep an eye on battery level on the BMS and then let the solar top the batteries back up.
