fishheadbarandgrill
- Jul 15, 2018
- R-29 Classic
- Non-Fluid Motion Model
- Sunfish; Vespa GTS 300 Super
- Sea Shanty
Thought I'd share my recent experience that appears to have fried the charging/power pass through capability of my Promariner Combi. Yesterday I returned from a couple of hours underway. I connected shore power. AC Line 1 and 2 illumined green. I turned on the battery charger breaker and then turned on the Combi at the remote panel. When I turned on the Combi, noticed a very faint red light in the reverse polarity indicators. I could barely see it but it was present and not bleed oner from the Green AC Line 1 and Line 2 indicators. I did some quick visual inspections and couldn't see any reason for a dimly lit reverse polarity light. I eventually turned on the genset and the reverse polarity lights went out. So that told me the problem was either the pedestal or my cables. Figuring both my cables didn't go bad at once, I informed my marina that the pedestal has a problem. They changed out what they thought was a bad outlet on the pedestal this morning. When I lit off the Combi, the unit went into inverter mode immediately. The charging function would not initiate. The reverse polarity lights are not illuminated. After many calls with Tim at RT and Promarinaer Tech support, I've ordered a new Combi. I did verify good AC voltage into the Combi. There were no faults lights or popped circuit breakers on the Combi. AC Line 2 working okay (the two Reverse Cycles circuit)
