Prop Questions
aroett
R-29 Classic
Ryk
Hello all,
I have a 2010 R29 Classic with a Yanmar 6BY260 engine. The present prop is: 18” diameter / RH / 3-blade / 17” pitch.
Since I’m not getting full rpm (3800 instead of 4000) and running hot, I’ve been recommended to reduce prop pitch. Some questions to you wise folks:
1. What is the factory specified prop size and pitch? Does anyone know what they have on this type of boat?
2. When putting prop back on. Are there specifications on how tight to do the nut? Anything else I need to know before taking off or putting on prop?
Thanks for any feedback!
Adey
Ryk (2010 R29)
Contact ACME Marine. https://acmemarine.com/. They provide props for Ranger Tugs. They can confirm the proper size prop for your boat.
Before I started changing the prop: Has this always been an issue or has it slowly occurred? Is the bottom and running gear clean? Have you added more items to the boat? All these items can change performance.
