R23 Power Reset/Test Button panel
Nickc
FMLT2378C919
Spirit
I noticed on my 2019 R23 there is a NORTH SHORE SAFETY reset/test button panel located near floor on the back bulkhead of the cave berth. Occasional I have noted that after plugging back into shore power at the slip, I have to press the reset button on the panel to get house power. Any clue why this is happening and how can I avoid this from happening?
Hello. I have a 2018 R-23 but I don’t see this reset/test button. Can you post a picture of it?
Karl
Are you talking about this?
PM me your email- i have a photo i could send (don't know how to post)..not able to pull up CruisingElvinRay link photo to see if same as mine.
Our 2018 R23 doesn't have that panel and our AC panel is different too. So sorry, I can't help you.
In order to see the image, just copy and paste the link after beginning with https: to your browser.
Peter
We always have to reset the switch after plugging into shore power. Seems to be a safety feature. We did have an issue on our 2019 R23 with the shore power connector at the pedestal was worn and wouldn't make a good connection unless we had the plug in the right spot. It keep tripping that device. I had the marina replace it and problem was solved. Hope that helps.
https://photos.app.goo.gl/Huvsc47poMiGD3No6
Also found this info.
https://waggonerguide.com/elci-protected-shore-power/
Bruce
thanks for informative follow up.. My reset button is the same- however I did not know the procedure for reset that you photographed....TKs.... also Very informative ELCI article.
