R25 2024 Inverter Model
ASHLEYPYNN
R-25 (Outboard)
FMLT2510G324
The Reel Smooth
What specific inverter model is used on the 2024 R25? I’ve got these pics but am hoping there’s a general standard instead of having to remove or from the wall.
Pretty sure it’s a Kisae. I’d guess SW1210 but I don’t know for sure.
Thanks Jesper. It’s definitely a KISAE just trying to find out out if it’s the CSW2012 or if it’s the CSW2012-X. I’m working on a LiFepo4 upgrade and am hoping to not having to take her entire inverter off the wall if possible
I love Gemini AI. By plugging all the info in your picture and your boat, it came back with the following: On 2024 Ranger Tugs (including the R-25), the standard OEM factory configuration is the CSW2012-X (2000W / 12V pure sine wave inverter with integrated 30A automatic transfer switch).
How to Confirm Without Removing the Wall Mount​
  • AC Terminal Box: Look at the bottom or side access panel. If there are flexible AC conduit lines/romex entering a dedicated hardwire terminal compartment, it is the CSW2012-X.
  • Shore Power Bypass Test: Plug the boat into shore power and check if the AC outlets stay energized when the main inverter power toggle is switched off. If they remain powered on shore power, the internal 30A transfer switch relay is active.
Hope this helps!
Mike
What specific inverter model is used on the 2024 R25? I’ve got these pics but am hoping there’s a general standard instead of having to remove or from the wall.View attachment 27889
Kisae SW1220. True sine wave, 2000 watts.
Same one that’s on my boat
@ASHLEYPYNN
Here's the manual.
Here's the data sheet.
I converted my boat to LFP. I had to install a Kisae 60 amp battery charger dedicated to the LFP house bank. My 20amp battery charger that came with the boat I use today to charge the engine and thruster batteries only. But the Kisae 2000 watt pure sine wave inverter works great off LFP.
Here's the electrical schematic that I designed and installed on my boat.
For additional info:
