R27 outboard fan switch?
Bsmith
Welaka, FL
FMLT2735J223
PDQ 34’ POWER CAT-SOLD
Elixir
On my 2023 RT27 (outboard) there is a switch on the dash marked “fan”. When turned on the switch illuminates but I can detect no fan activation or anything else. Can you tell me where the purple with white stripe wire marked “defrost” that connects to this switch leads to? Since there is apparently no defrost fan I would like instead to add a 12 volt power outlet with a pair of USB charging ports mounted on the dash and use this circuit for power. If the hot wire from that switch is accessible that might help determine where this proposed outlet can be mounted and save some wire routing. The charging port(s) draw a max of 6 amps DC and recommend a 10 fuse. Can you tell me if there is a breaker or fuse on this circuit and what is it’s rating? TIA.
