Raw water pump for toilet
Jclima
I have a new to me 2018 Cutwater C302 and I'm working through all the little issues that either did not get caught in the survey or just learning about the boat. I have an issue where when I flush the toilet, the vacuum works but it does not add water. I hear a a click but no pump. I see the water line that goes from the raw water strainer towards the head but can't figure out where the pump is or where to start troubleshooting. Any help is welcome.
On a 2017 Ranger 29, there are two 90 degree ball valves aft of engine for raw water:
1) engine water
2) toilet and cockpit wash down water (starboard side, also near pump)
If wash down works, then pump and filter should be good for toilet. There is a switch adjacent to wash down garden hose outlet.
1) engine water
I'd think it would be a pump somewhere on this hose or forward of it toward the head.
I don't know about the Cutwater 302, but on the similar RT31, the water for flushing the head is fresh water from the water tank. So to fill the bowl, the water pump needs to be turned on. I'm pretty sure the RT 29 uses raw water for the head.
The pump for the head on my 2019 C302 is located under the cockpit hatch, right under the cabin door area..supple line comes from sea strainer on port side (bronze) as shown in other replies/post. Hope this helps.
The pump for the head on my 2019 C302 is located under the cockpit hatch, right under the cabin door area..supply line comes from sea strainer on port side (bronze) as shown in other replies/post. Hope this helps.
Oh! I completely missed that. Will check this weekend. Thanks a ton!
I'm following. I changed my Joker valve and when I flushed the head, it had no raw water coming in. The raw water valve is open and I have the same pump as in the picture above on my 2019 C302C. I'm thinking it could either be a fuse which I cannot locate or I pulled loose a wire connection when pulling out the head.
Ok, it is there hiding behind the storage bins. I was also not able to locate a fuse so I ordered a replacement (http://bit.ly/4ji6BD5). Getting here next week. Will keep the thread updated.
Before replacing the pump, check that the connection is in tact from the pump to the head. I pulled it apart when I last changed my joker valve, an annual maintenance activity, and the raw water pump worked fine once the connection was restored. You have to partially pull out the head to access the (white on my boat) connectors. I also was unable to locate and fuse for the raw water pump.
Good point. I have been avoiding pulling out the head but you are right.
Most of us have gotten good at it since you have to change joker valves so often. Presuming it's the same Tecma head, remove 2 screw cover caps and use a socket wrench, they both come out quickly. On my boat there is a white connector that you can confirm is: a. connected and b. if connected, do you have power. If both are OK, then likely the pump is bad.
