MechGuy
- Feb 19, 2024
- C-302 C
- Sapphire
I noticed I had some water in the cave area on my 31 that appears to be coming from one or both of the opening Jim Black windows in there. I found that the latches don't provide much compression on the window seal when locked. I removed one of the latches and noticed a clear plastic insert that appears to be instrumental in applying compression to that window seal, which is worn. Does anyone know if these clear inserts are replaceable? Thanks.
