Rule 1100 Model 27SA
Coonbay
R-25 (Outboard)
FMLT2511I920
Wastahi
We own a R-25 with outboard. Would like to know correct wiring for the three wires to the two bilge pumps below deck. Below is pic of existing wires connected to pumps. Pump works manually but does not work when bilge is filled with water. Also, no electrical sensing every 2.5 mins.
Thanks for help
Hello,
The wiring in the picture is correct. Please check the wiring at the 24-hour block. With the bilge pump hooked up, pull the fuse at the 24-hour fuse block in the Q-berth and tell me if the light turns on with the fuse pulled. If it does not turn on, then the wire at the 24-hour fuse block needs to be checked for a good connection. Ensure it has been crimped correctly and that there are no loose wires. If it turns on then you got a bad bilge pump and needs to be replaced.
Jared
