Bruzer
- Jan 16, 2024
- C-24 C
- Non-Fluid Motion Model
- Beneteau 10R
- Split Second
Our Ranger Tug, a 2020 R 29 S LE, HIN: US-FMLT2915K920, with a Volvo D4-300 (1285 hours) loses its fuel prime. About three weeks ago, the engine would immediately start, run for about 1 minute and then cut out. When I attempted to restart the engine, it took several seconds of cranking before the engine would start. It seemed to be starved for fuel. About a week later, the same symptoms happened. This time I used the priming pump on the top of the secondary filter and it took about 35 pumps before there was pump was pressurized. The engine started right away and contiinued to run. The fuel filters on the engine have been routinely replaced, but I decided to replace the filters anyway thinking perhaps I had gotten some bad fuel. When I examined the used filters, there was no sign of crud or water in the fuel filter or the fuel that I drained from the filters. This past weekend the engine started right away, but cut out after about 1 minute. Before starting a second time, I opened the fitting on the top of the secondary filter, and it took about 20 pumps before any diesel came out. Once the air bubbles were purged and I had a steady stream of diesel, I closed the fitting. When I started the engine, it fired-up immediately and did not cut out. There are no traces of leaking diesel from the tank to the filters and to the engine. I discovered online that the rubber priming pump on the top of the filter housing can degrade and air leaks can occur. Does/can this happen and is this a possible cause of the secondary filter to lose its prime? There is some corrosion where the rubber priming pump meets the metal housing. Would an air leak on a fuel line fitting also cause these symptoms? Any trouble-shooting advice would be greatly appreciated before I spend about $500 on a new housing and filter. Thanks.
