Submariner
Channel Surfing
- Feb 2, 2020
- Everett, WA
- Website
- www.letsgochannelsurfing.com
- R-27 (Outboard)
- FMLT2702C021
- Non-Fluid Motion Model
- https://tinyurl.com/yrv84xdm
- Channel Surfing
Remedy2":3bnsbfs3 said:Man this thread turned a direction I didn't see coming! Reading between the lines and straight out advice:
2. The Power Tech 5 blade prop seems the way to go. My only concern is you're running a single; I'm running doubles. Do they offer a 30 day "try out" or return?
Careful what you wish for when you post online. :lol:
I'm working directly with the President and VP of PowerTech on identifying the ideal prop for the RT27-OB. Along the way, we're learning lots which will benefit other boats in the Fluid Motion lineup.
I'm specifically working on solving a problem based on our SE Alaska trip which is how this all started.
I want to make it from Shearwater, BC to Prince Rupert, BC, on a single tank of gas in a days travel. It's 204 miles. Hartley Bay and Klemtu just aren't reliable fuel docks in between. I need to do this on about 120 gallons of fuel and I don't want to give up my mid-range, amazing hole shot, and improved reverse thrust to achieve it. It cost me 170 gallons with the PowerTech OFS4-15. I can easily do 204 miles on less than 100 gallons of fuel if I do 7 knots. But I want to run this stretch at 25 knots. I've always felt the 3 blade doesn't provide enough stern lift on my boat where a 4 blade prop does.
I've been watching the Sharrow prop performance but just can't get by the $5k price tag with a 5+ year return on investment. I also recognize that all prop's eventually hit something. Local prop shop's know how to repair traditional prop's. I'd also like to know what's possible for performance on a traditional prop that sells for less than $1k.
I've got all the performance data needed as I keep great fuel and mileage logs on my boat. So I reached out for help and found some of the best in the boating industry with PowerTech.
The work I'm doing is with custom made prop's direct from the PowerTech factory. The prop I'm currently testing is a SCE5 modified (14" diameter, 15 pitch, 5 blade). It's the best I've tested thus far and beats the PowerTech OFS4-15 (modified and unmodified) without question. It also outperforms the Yamaha SWS II 3 blade.
So when I say "modified", that means "unavailable to buy as it's a prototype".
Most prop resellers have some form of an exchange policy which usually involves a nominal fee and a 30 day trial window.
