Phil Nersessian
- Feb 24, 2016
- C-24 C
- Non-Fluid Motion Model
- Cutwater30LE
Hi all, Having a problem with my 2016 C30. when I try to start it I get an error message"check shift actuator, gear shift not available, move control to neutral", The control is already in neutral. It will start in "throttle only" mode, but won't allow me to get out of it. I tried swapping the control with the one on the command bridge which had an identical part# and am now getting another fault"Check EVC system, control unit has communication disturbance" which has not gone away even after switching them back.Was very careful about plug locations and contact. I have tried powering down both with the ignition on and off to no avail. Any Ideas?
